do-it-yourself engine mounts
zmepro
Protege5
ok, i have read somewhere ( i think it may have been protegeclub) that you can make your own stiff engine mounts by injecting the stock ones with some kinda urethane, is this true? if it is how would one go about doing it?
the product is a pourable polyurethene which is available in two durometers. It can be purchased from a company called McMaster Carr. You will need to dam the open areas with tape or putty. I truly do not see how to do the back one without removing it, or else, a big mess you will get!!!!!
Godspeed!
Dave
