DailyDriver
Answer: Runflats are a bad idea, got it.
Good point.... but an additional reason to look at runflats is the added reliability of not having the tire disintegrate and break the fender / rim etc during a high speed blow out. When you add up all the "advantages" of runflats, it starts to make a little more sense. When the OEM tires wear out, I'm sure I'll be upgrading to some other high quality "expensive" tire regardless, so I'm not overly worried about expense... unless it's truly out of hand. (I have not yet looked at runflat tires for this car / prices.)
hell to the no.
- Although there are good run-flats, there are always BETTER regular tires available.
- Run-flats are more expensive.
- Run-flats are never AS comfortable as a normal tire.
- Run-flats are heavier. You just ditched 40lbs of weight the car barely cares about in favor of a few pounds of unsprung weight that the car DOES care about.
- In a car designed to carry a spare, it's generally engineered as part of the crash safety system. You just saved 40lbs but killed someone in the back seat.
Runflats are tires that have their sidewalls reinforced, which according to BMW's recommendations, allows you to continue using a flat tire for about 100 km's (62 miles) at an av. speed of 80 kph (50 mph) so you can find a shop to repair it... As long as its not a damaged sidewall, they are repairable, just as any tire would...iam sorry but i would like to know what are runfalt tire??
Max Load: 1389lb NT / 1235lb RF
Tire Weight: 21lb NT / 24lb RF
Anyone that knows anything about wheels, tires, brakes, and suspension; knows that 3lbs of unsprung weight is nothing to sneeze at, and if it can be avoided...it is. One of my main factors in tire purchase, after I've narrowed down my choices, is actually tire weight.
