Yesterday I changed the driver's side rear pads, and simply using an allen wrench to turn the adjuster screw worked, but it started to rain and I ran out of daylight so I thought I would do the passenger rear today. But on the pasenger rear, as I turn the adjuster screw nothing happens, I've now learned the piston needs pressure against it, can I use a simple clamp to apply pressure, or do I need the brake tool that will apply pressure and rotate at the same time?
Cheers
Cheers
