miss_steele_msp
- mazdaspeed protege
Here goes. What is heel-toeing?
This is a no brainer and is probably already posted on this thread. Down shifting saves gas as it cuts fuel to the motor. Also, and probably the most important is it is safer to be in gear than not. There are a lot more movements to put the car in gear and go to get out of the way of an accident. If you use the engine and brakes in sequence you will always be prepared for the unknown and save gas... Win-Win!
That's not that big a deal, but you realize you're still adding wear to the clutch by doing that? You can feel the car slow down as you clutch out through the friction point, right? You understand what is happening when you do that? The motor is turning slowly (at or near idle) and you are clutching into gear in a lower gear that wants to be running at a higher RPM, and as you get to the friction point the clutch wears against the flywheel as it brings the motor up to the appropriate RPM for the gear and speed you are moving at. The wear, when braking, happens across a smaller RPM range than just using the clutch because you're braking through the entire manoeuver which brings the speed (and thus the RPM the next gear is going to want to be at) of the vehicle down.You guys are making me worried that I sometimes use the clutch when downshifting and slowing down with the brakes to engage the lower gear..
Like I'll keep it in gear and use the brakes to slow down. Once the rpms are too low, i'll push the clutch in and downshift, ease back off the clutch while still using the brakes. By the time i've approached the turn, i'll either use that gear or downshift in mid turn one more time with rev-matched assistance. Otherwise, I always rev-match. It's my braking approaches when I do it, or with this slipeery weather, i'll try to stabilize the car better rather than having too much inertia throw the car forward on slippery road.
I have never found a need to really do that. I almost always have enough space between me and situations where I have to slow down that I can rev-match downshift and then brake through the gear, and if necessary come off the brake and do it again. I don't know that I'd worry about what you're doing, per se, but you should be aware that doing that is increasing clutch wear even if it is only minimally.
Justify this position. Defend the idea that normal driving wear is somehow worse than, uh... normal driving wear, because that's what you just said. Explain how an engine running in vac and generating less heat as a result is something to be avoided but idle or acceleration are not. Defend the idea that an engaged clutch wears on the clutch somehow.Downshifting may not be bad but it does wear the clutch / engine just as normal driving does.
See, if more people thought this way, people wouldn't be trying to do bizarre logical gymnastics to come up with the idea "BRAKES ARE CHEAPER." The clutch is a wear component on the car. Don't abuse it, try to minimize wear, and it will last the life of your car.Yeah I definitely know it's putting on wear. My logic behind is was, it's ultimately going to happen regardless.
