deactivate lost keyless entry remote
Hi,
We've misplaced (LOST) one set of our keys that had one of our keyless entry remotes attached. Is there a way to deactivate the keyless remote so it can't be used to locate and/or open the car?
Thanks.
Yup. Anytime you program a new remote in (you can have up to three) you have to program in all working remotes again. If you go through the programming with only your single remaining remote it will de-program the missing one. Here's the programming method. Note you only need one working key in order to program remotes.
Spare Remote Programming said:
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
Your real problem is the fact that you now only have one working key. Here's a quote of another post I made to explain why.
icspots said:
The way Mazda's keys system works is this. You can have up to eight keys programmed to start the car. Keys can be programmed in two ways. Way number one is you program them yourself for free in about 15 seconds. Way number two is the dealer plugs into your car's computer, clears out the existing key codes and inputs all the new ones.... this takes about 45 minutes and will cost you anywhere from $50-150 (depending on the dealer). I think you can guess which one you'd rather do, right?
The catch. You can only use the self programming (way number 1) method if you have two working keys in hand. That means if you lose one of your two keys that the ONLY way to get a new key programmed is to go through the dealer. On the other hand if you add a third key now and program it yourself then you're protected from every having to visit the dealer for key programming. If you should lose one of your three keys then you can just go out buy a new key, and since you still have two working keys you can program in the new one yourself. As a bonus the way the PATS (Passive Anti-Theft System) works anytime you program in new keys you have to reprogram in any existing keys as well. So if you lose your third key you can just reprogram the two you still have and that lost key will no longer start your car.
Mazda uses a standard transponder key across basically all of their models, though the chips can differ country to country. All NA 3's will most certainly use the same key though. The standard key is p/n F1Y1762GX and will run you about $22 from our forum sponsor at www.onlinemazdaparts.com (Jason aka bagman1). Even if you continually lose keys and keep having to replace them you could do this four times before spending as much money as a single key/programming from the dealer. Jason will even cut the key for you for free to save you the trouble.
And to finish it off here are the programming instructions for keys.... yes it's really that easy.
Spare Key Programming said:
Items needed:
1. 2 pre-programmed transponder keys.
2. 1 new transponder key
The timing is critical to this procedure, please read through the entire procedure before attempting.
Procedure:
1. Insert one of the pre-programmed transponder keys and turn the ignition to "on", leave on for at least one second (I wait until the red key symbol in the instrument cluster extiinguishes), remove the key from the ignition.
2. Within 5 seconds insert the second pre-programmed key and urn the ignition to "on" for at least one second but no more than 5 seconds (use the key symbol for this as well) then remove the second key.
3. within 10 seconds insert the new key in the ignition and turn the ignition to "on", if you are successful the red key symbol will illuminate then extinguish after about a second.
