Dawes Devices Air/FUel Gauge
This will only work with a stock sensor which is narrowband. Check the voltage output.
Most people will tap into the rear side of cat and the cat material will help to stabilize the voltage results. This is a wrong reading, but people think their autometer or dawes meters are working great! In fact, the real results are only on a sensor that is pre-cat.
It will not work with a wideband sensor.
If you want blinky lights dancing all over the place, with no real use in tuning, then this device is for you!!
