Hey guys,
I've posted about this before. I've had a cylinder misfire issue, but for a while it seemed to go away. Now its back. Its been getting worse. I've pulled all the plugs and coils and I'm confident its not an electrical issue. Haven't tested compression yet... but I wanted to run these symptoms by people and see if anyone had any suggestions.
1 - Its rough on idle, and its rougher when i first start than once its warmed up.
2 - Its a bit rough driving, especially at lower RPMs, and when I push it harder.
3 - Its been getting slightly worse over the past week.
I'm thinking its lost compression, which explains most of these symptoms. Which would lead me to believe its either the gasket head or the valves. What do you guys think?
Also, if it is either of those things, what do you think I'm looking at for repairs? Anybody?
Thanks much for your help!
