Cx5 6 Speed Manual compatibility
Jtd83
Hi everyone,
I am unfortunately in need of a new transmission in my 2014 6 Speed fwd. 3 gear is almost gone and 4th is on the way I believe.
My question is, will the Mazda 3 6 speed be the same? They have different part numbers but share the same clutch and even mount part numbers. In my area, the 6 speeds are more plentiful and cheaper than the cx5.
Anyone know if there is a tea difference between The 2?
Thanks
The gear ratios may be slightly different but it might work ok... Tire size on 6? Same engine size?
Hi everyone,
Thanks
I would confirm the axle P/N to make sure they are the same.. afterwards your cx-5 will probably be faster than most due to gearing lol
