Nope it doesn’t!!!Does it open with the button on the driver rear door (door with the faulty window)?
So there is no chance of fuse issue?Sounds like a motor/regulator issue. Pull the door card and see if anything tries to move when you push the button. Likely won’t and you’ll either get to learn how to replace a regulator or take it to a shop to do it for you
Much appreciate your help… in my attached diagram, it shows 2 different fuses for passenger seats L and R. So, if I am right, they are not on same fuse!!!Definitely not a fuse issue as all windows are on the same fuse and the other windows work. What you need to do is check for power and ground with a multimeter or light probe at the harness that plugs into the motor of the regulator when you operate the switch with the ignition in the ON position( engine not running). If you have both then that confirms a dead regulator. If you do not have power and ground then you have a switch or wire harness issue
That is for heated seats, not power windowsMuch appreciate your help… in my attached diagram, it shows 2 different fuses for passenger seats L and R. So, if I am right, they are not on same fuse!!!
I see… but I do not have any buttons for heated seats to turn them on or offThat is for heated seats, not power windows
