Late last year I had a sloshing sound in the dash of my 2008 CX-9.  The sloshing sound continued to the point where, when I turned left (if I remember correctly), water would drip out of the evaporator case through the blower motor of the climate control system... and drip onto the passenger side floor.  I eventually figured out where the evaporator drain is.
I've attached a photo. Take a look in the center "tunnel" underneath the truck. There is a silver heat shield in the tunnel, and the opening of the drain is behind it. The heat shield is bendable. My scientific solution was to bend the heat shield back, put a wet/dry vac on the drain, and bend the heat shield back into place. I'll bet almost a gallon of water came out.
Soon after my blower motor quit working. I took the truck into the dealer. They said the motor was fine, but a relay needed to be replaced. No worries since.
