2013~2016: CX-5 Tail Light Assembly - How to or replacement
julian926
Mazda CX-5
I couldn't find it through the search. I was wondering if there's a good DIY out there on replacing a driver's side Tail Light Assembly. I have a 2013 CX-5 GT.
Is it easy to replace and install? Or, should I get the professionals.
Thanks!
Julian
Easy as. Are you talking about the one on the body or the tailgate? If its the first, you open up the cover in the boot where you replace bulbs, then unscrew 3 10mm nuts. If its the latter, you have to remove the trim.
