Anybody have this? Here is what I have done. It's a CX9 but same front end and maybe you guys can shed some light on my nightmare.
Tighted all 12 cowl bolts to spec and test drove, removed cowl plate from vehicle and test drove, removed end links and secured sway bar and test drove, removed lower engine covers and test drove, replaced right front LCA(dealer), sprayed all bushings with fluid film. Sprayed upper strut area with fluid film, checked torque on sub frame bolts, checked torque on upper strut mount nuts. Checked engine mount bolts. Still creaks/clunks
Started at 7k. 14k now. 2022. Picked up with 2 miles on odo. Helped pull the plastic off the paint. Only driver. Struts and upper strut bearings/mounts?
youtu.be
2022 Mazda CX-9 Creaking Noise.
This is with the sway bar end links removed and the sway bar secured out of the way. so its not the sway bar or end links. I also removed the cowl panel aft...
