CX-5 2013 Headlights and Rear lights start blinking all of a sudden when parked
athique
Mazda CX5 2013 FWD Full Option
Greetings,
I am facing an unusual problem in my CX5 (2013) . While the vehicle is parked and switched off completely after 15 - 30 minutes the lights start blinking (headlights and rear lights) and this continues and sometimes happens after 2 -3 hrs (sporadic).
Initially the anti theft alarm used to sound and now for the last 4-5 days its only the blinking of lights that is noticed.
Any feedback and advise will be appreciated.
Does the car have an aftermarket alarm and/or remote start system? Maybe with it's own keyfob?
Have you tried replacing the batteries in the OEM or aftermarket keyfob?
Upvote 0
No aftermarket stuff in my car, as is orginal state since purchase.
FOB has new battery, Mazda Service center replaced the driver side lock assembly.
Post this if i keep the auto light on (Inside the Car) it suddenly lights up , i have switched to off mode now to prevent battery drain.
Now i have ended up with a bigger problem.
CX-5 2013 AT / Engine / TPS / Traction Control lights on
Upvote 0
Possibly a defective new battery? Or a wiring issue (maybe rodents are chewing away at your wiring)?
I would certainly look into the wiring issue before jumping to changing the transmission as suggested in your other thread.
Upvote 0
