Custom poly bushings...
Mike R
Contributor
Anybody know where I could get some custom bushings? They look like a common size. I have emailed Energy Suspension twice with no reply.
Here's the size...
Bushing OD 1.5"
Bushing ID .75"
Sleeve OD .75"
Sleeve ID .5"
The length of the sleeve is 2 7/16"
Bushing overall length 1 1/4", where 1/4" is a 1 15/16" OD lip(the flared end)
I'm looking for a lower durometer polyurethane than the regular bushings that come in the AWR mounts. Hoping to reduce vibration a little but still keep the engine from moving around.
try looking up polyurethane rod (watch the remarks now! :p) on mcmaster.com or something. Buy a length with the duro. you're looking for and cut and bore out a hole to your size. Depending on the duro., you might be able to actually machine some (of the harder kinds).
