creaky d-side seatbelt fix
anyone know where it is on here? i know i saw it before, i but i can't find it via search.
the driver's side seatbelt on the right side creaks when it moves any amount. i could very well unbolt it and lube it up a bit, but i'm almost posi i saw something on here before, documented.
thanks.
are you sure its the drivers side?? i am almost 100% positive it was the passenger side that was creaking. I know on mine its the passenger side that does it.
mine's def on my side. the passenger side has an identical setup though so i can see why whatever is affecting mine could be affecting yours.
I shot mine with WD and it went away just fine. I took a old rag and put it around the floor to catch over spray and gave it a quick blast, worked great.
