but either way they gotta repaint the whole bumper if they try and fix it. I would try and find a used bumper and if needed pain it and if not even betterELEmental59437 said:You dont need a new bumper. You can have it fiberglassed on the back and they can use body filler and repaint it. It will look better than new. I have also seen shops melt plastic to rejoin two pieces and then use body filler. That part of the car does not flex much so fiberglass is a good solution. If you get it repaired, you are looking at about $175-$200 US from most shops.
