CPE Turbo Inlet Nviscid Pipe
pcpower
Anyone know if the CPE Turbo Inlet Nviscid Pipe would have any issues fitting with an Injen CAI?
I see a lot of PG and COBB TIP reviews on here but not much in regards to the CPE.
thx
I have Injen CAI with CP-E inlet. Installed them at once with no problems at all. Pita to put in inlet because it is really huge. Just don't forget to put the clamp on inlet (compressor side) BEFORE you put everything on, I failed and had to make all the job twice (rofl)
thx 4 the heads-up
hey did you have any issue with the Vacuum Hose from CPE? the instruction guide says it's 5/8" x 10" long, but just looking at it the hose looks more like 5" long. does that sound about right??
thx
It should be enough that is basically all the stock one is.. But be careful taking it off the boost solenoid as the tips break off really easily.
also, I think the cpe comes in 3 and 2.5 sizes
I have the 3 and yes, it is tight
pull the bat box. trust me
and why does no one ever mention the hose from the valve cover?
do other intakes hook it into their maf body ?
