CP-E catted downpipe owners...
I wouldn't really buy on a brand name anyways...buy based on the objective points of the product. Who cares if Vibrant makes it -- if it's stainless and fits right, and the specifications match another company, it's probably not different.
I admit that I don't entirely trust Vibrant, but it does speak volumes when you see how long they've been around. They must be doing something right.
I found out what the part numbers are on the MS6/ MS3. the numbers depend on the manufacture date of the car, but both the turbos are having problems.
L3R9L3700F (most 06 models, and some 07 models.
L3Y11370Za (replacement for the 06 turbo, and OE for most 07 models)
I've also found that part of the issue might be related to EGTs being a little hotter.
I was also told by the local dealer that they have been instructed not to do any work on the turbos unless the exhaust is stock except for a different muffler. He showed me the email from MNAO. All I can say is be really careful with what you do to these. They are pretty well tuned from the factory.
Some hope I have had though is I switched brand of oil from full synthetic vavloline to Royal purple, and it hasn't had the same amount of smoke.
You can also run you car through a defoul mode. to do this make sure you parking brake is set. Turn all accessories off. leave it in neutral. Press the gas down, and hold the RPMs in the 3500-4000 range for about 2-3 minutes. When it's done the car will return to idle on it's own. When it does take you foot off the gas pedal. By the way make sure you don't have the exhaust blowing on anything. It's going to get really hot.
If anyone has seen GM do it on on the newer duramax with full exhaust done it'll start thing on fire within seconds. Most I've gotten my MS6 to do was burn the hell out of my friend's leg
Part of the problem is also the first cat on the car. it collects a ton of junk in it, and the defoul mode that is supposed to come on during highway drives helps clean it out.
The quote in red would explain my issues with the irratic P0421 CEL...
I still (knock on wood) haven't gotten a CEL...
I wonder what this "defoul mode" does to the high-flow metallic cat...?
