CorkSport Mazda 3 2.0L Liter Standard and SkyActiv Exhaust With Race Pipe - SOLD
Status
Not open for further replies.
DanaLamon
2013 Mazda 3
I really liked this system and it is under two hours for install. I am only selling it as my 2013 was totaled when some lady ran a red light and ripped off the front end of the car. The exhaust was not damaged at all. The original cost is over $500 and that doesn't count shipping for the large box.
Here is what CorkSport says:
Maximize airflow and increase power with the CorkSport Power Series Single Exit 60mm Exhaust for the 2010-2013 2.0 liter standard and SkyActiv Mazda 3.
Featuring dual resonators, a slip fit compression connection to the aft end of the catalytic converter and a single tailpipe design, the CorkSport Mazda 3 exhaust eliminates the factory tailpipe muffler and features a non-resonated CorkSport dual wall 90mm exhaust tip.
During testing, the CorkSport Mazda 3 Power Series Single Exit Exhaust went from a baseline of 118hp/110lb ft. of torque to a respectable 135hp and 123lb ft. of torque at the wheels when tested with the CorkSport Power Series Short Ram Intake. The 2.0L results are moderate at the bottom end (with around a 4-5hp/tq gain) below 4000rpm with the majority of the power coming on rapidly at around 4500rpm and held steadily to the 7000rpm redline. This really shows how constrained the stock system was for the smaller 2.0L engine.
The CorkSport Advantage:
Features dual resonators, a slip fit compression connection and single tailpipe design.
Mandrel bent Stainless Steel T304 construction for corrosion resistance and clean stylish look.
Optional 60mm racepipe with or without high flow catalytic converter* attaches between the factory header downpipe flange and the front compression fitting of the cat-back portion of the exhaust system
Distinctive performance sound mild but noticable at cruise and idle and a distinctive growl at wide open throttle and free rev.
Picks up all of the stock hanger locations.
Power Series exhaust AND racepipe will not cause a CEL (Check Engine Light).
Corksport Service and Support: Receive a 2 year warranty, full color installation instructions, all of the needed installation hardware, and knowledgeable telephone installation support.
List Date: 8/11/2014
For more info, click here to view the original listing: CorkSport Mazda 3 2.0L Liter Standard and SkyActiv Exhaust With Race Pipe
SOLD
********************/analytics/ga/mazdas247
Status
