so what the dilly yo? during the test fit, were the stock fans on the car or not.........how about now? i've had a few....(cheers)....need to clarify....if the fan needs to go then i'm out of the GB....i'll just get a side mount and hard pipes....can someone from corksport confirm this.....
It has been confirmed. Yes, you do have to remove a fan. I PM'ed Derrick at Corksport and in the CS FMIC thread you can see the installed pics and you can see the fan has been removed. You do have to remove your AC aux fan to fit the turbo to IC pipe. The claims is the car is fine without the fan and there has been no AC performance issues. I can understand that in Southwest Washington/Portland, Oregon area were the climate is pretty mild. I don't know if you guys in hotter climates that use your AC will be impacted. Previous threads state you can buy a SPAL for pretty cheap around $100 as an upgrade and that is supposed to fit fine. Good luck!
Same questions in the CS FMIC GB Thread. Word!
