did an oil change on the speed and noticed that my coolant overflow bottle was completely empty.....strange....checked the radiator and it was very slightly low.........now before jumping to conclusions and thinking i've got a leak i'd like to add some to the regular level to see if and how long it takes for it to go back down to where it's at now........
i checked the manual but am unable to find the info, did a search here along with calling two dealerships and getting two different answers......
1. if anyone has had coolant leaks where did they occur from?
2. did the speed come with long life coolant or regular stuff?
3. topping off the coolant...can i mix long life with regular and vice versa?
4. when flushing radiator....can i go from using long life to regular or vice versa?
5. what exact type of coolant should i use in the speed?
i've heard there were some problems with dex cool and being able to use regular coolant in systems requring such.......just want to clarify before i do anything. thanks.
