converting a mazda 6 to a ms6 awd drietrain
the basic list consists of engine with turbo and exhaust, transmission, full rear drive train, floor pan, full rear suspension, full car wiring harness, ECU, probably fuel tank and full fuel system.
what it boils down to is this: it would be cheaper and and MUCH easier to sell your current car and find a used speed6. if that is not an option, and you have the 4-cyl model, you could just turbo your current car, upgrade the suspension, and call it a day.
Agreed, you will be in much better position and most of all, probably cheaper to just buy a MS6 from the start. Less headaches and physical work.
