R rae rae Member : 2001 mazda protege mp3 Apr 4, 2012 #1 can anyone give me any heads up on replacing the coil or coils location,time ect
T tweety2300 Member : 2001 mazda protege mp3 Apr 4, 2012 #3 If its the ignition coils there's 4 10mm bolts holding the black plastic thing. you will see the coil packs they're held on each by 2 10 mm bolts total of 4. All in all take 10 minutes from start to finish
D DarkAngel Member Contributor Apr 5, 2012 #4 As stated before.... 1. Unplug the wires and connectors attached to the coil packs 2. Remove the 4 10mm bolts that hold down the coils ( only two coils as you see ). 3. Pull the coil packs up off the cover. 4. Assemble in reverse order. 10 minutes tops as stated before. Last edited: Apr 5, 2012
