I have this code P0171.
The engine idles fine in Park. The engine idles rough/low in Drive at a stop sign. And only when in Drive.
If this was caused by an idle leak at the intake manifold, I would think it would also idle poorly in Park and not just Drive.
Any suggestions other than clean the MAF wire? Or spray for air leaks using starter fluid etc?
I figure when you put it in Drive from Park, you make a switch with the shift lever and that switch tells the ECU that your in the drive mode and *something* gets energized/de-energized when you do that. EGR solenoid(s)?
Thank you. It's my first post on this forum and the car is a neighbors car. Both 02 sensors were replaced last summer (shop wired 'em backwards/upside down and I had to rewire 'em. Work fine when observed on the scanner while driving).
