Cobb SRI + Cobb AP? Who has both?
hyperpm
08.5 CPW MS3 Sport
I have a Cobb SRI and planning on getting Cobb AP. I'm putting down 250whp and 285wtq with just the intake. Does anyone have both? Any improvement by adding AP? If so which map? Trying to see if worth getting AP with current maps. Thanks in advance.
I have the AP and the SRI from COBB and I would recomend that you run the stage 1 map if you get it. I went from 15 to 17 psi with it, no hesitations or chugging. The power delivery is smooth and holds power until about 6,400 RPMS. Deffinatly worth it. First though I would really recommend getting some kind of aftermarket bypass valve to ensure you are holding the full 15 PSI without a tune. I was only running 13.5 or so without my bypass valve. Other than that, runs great and I recommend it. As for stage 2 it is only suggested to be used with a full turboback exhaust. Hope this helps!
are you the one that came to 76 station with your girl about 5-6 months ago? I was the guy that had black ms3.
