Cobb Short throw
taylorex
Subaru WRX
Its been a awhile since I installed the STS. Impressions are good and the feel is great. My one issue is that the COBB shifter its off center and when going into 5th gear I hit the console. Pics are stock and then cobb shifter.
Loosen up the shifter base mount bolts and pull the base as far to the left as it will go. There is some play and that will give you a little more clearance.
