Cobb obd2 connector question
ivan-msp6
Hi guys,
The obd2 connector has always 12V on it so no matter if the car is on or off, doors open or closed the AP always stays on...
So I keep on plug and unplug the AP when I turn off the car and I guess with time this connector will go bad.
Is there a way to leave AP always connected and having 12V only when the ignition is on or car is running ?
Thank you
you could have fun figuring out the wires off the dongle and changing it out to a ignition source instead. i would not recommended wire hunting without a schematic though. and this is not guaranteed to work also.
connect a switch to the usb cable, thats what i did.
Items Need:
-1 <acronym title="Cobb Access Port">AP</acronym> USB Cable
-1 Switch (I went with a slide switch from radio shack)
-Soldering Iron
-Electrical tape
Take your USB Cable, could be the one that came with the <acronym title="Cobb Access Port">AP</acronym> or any USB cable that has the correct ends on it (male normal size, and male mini size).
Strip away a section near the normal side to expose the wires inside.
I stripped away about 2 inches so i had some wire to work with.
You'll see white, red, black, and green and maybe a shield wire.
The wire you want is the black (ground) wire.
Cut it and strip away a bit on each end.
Then get your switch and solder one end to one position and the other to the middle position. So you should have one wire going to 2 of the prongs while the other is left empty. Solder the wires onto the prongs.
Once this is done you can tape things off so the wires don't touch then use some electrical tape and tape the switch to the wire. And thats it.
You might want to try it out on your computer before you tape it all to make sure it works. When the switch is in the far position on the side the wires are soldered the <acronym title="Cobb Access Port">AP</acronym> should be on and when its to the empty position it will be off.
If it works then tape it all up so it looks pretty and install it in your car. Now enjoy that everytime you park or turn your car off you don't have to unplug the cable just flick the switch.
