clutch going out?
1sicspeed
Contributor
2003 Mazdaspeed Protege
I was sitting at a stop light and I let the brake go just to sit there and my car started pulling as if I was engaging the clutch pedal but the clutch was on the floor. Any suggestions on what it is? I'm thinking its the clutch master cylinder but I do not have any fluid leaking in driver floor board.
Please help
there is also a clutch slave cylinder. just have someone pump the clutch while you watch how it behaves.
The slav cylinder is workimg fine. It looses pressure while sitting still. And if I hold it in. The slave cylinder isn't leaking any fluid
it is still a factory slave cylinder! i have ordered a OEM master cylinder and OEM slave cylinder! RyanJG if that is not it i will be contacting you on the clutch about sending payment! Parts come in Thursday 7 Nov
Thanks for all the suggestions. It was either the master cylinder or slave cylinder I changed both of them and it works better than before it was slowly going out!
