Clutch Adjustent Question
needforspeed6
07 Mazdaspeed 6
I recently performed the clutch adjustment procedure in the How-To section. I backed off the clutch both approximatley 3 turns but I am still finding that the clutch engagement point is too high. For those that performed this mod, how many turns out did you do? I don't want to mess up my clutch but I would like to adjust it further if possible. Let me know what you guys did. Thanks!
http://forum.mazda-6-club.com/mtx-transmission-discussion/150441-howto-clutch-pedal-adjustment.html
http://forum.mazda-6-club.com/speed...306-adjusting-clutch-pedal-2.html#post2414564
WITHOUT THE DASHES
Look through these. If your still stuck back off on the adjustment, there were two adjustments you had to make though if I remember correctly.
Holy ******* hell why the **** are you guys blocking links?!?!? It's hard to help someone out if you can't even point them in the right direction!!!
