Clocks not synching up...Please help!
I have a problem with the clock on the upper display synching up with the clock on the navigation system. Had the car about 3 months and I figured it would fix itself. The weird thing is this....the minutes and seconds seem to be fine, but the hours are 5 hours apart...(i.e. the Nav is the correct time at 4:15...but the other display says 9:15).
I appreciate your help in advance.
Matt
This may sound dumb - but did you "setup" your nav to know where you're located...? Apparently, there are different "zones" (not the same as time-zones) for the Nav system to pull data from - not sure how to better describe this.
Not a bad question....at least someone is paying attention. Everything is set up within the Nav the way it should be. The clock on the Nav is correct...the display clock at the top is 5 hours fast exactly.
medcenter, if you go to nav menu, then to calibration, there will be an option to set the clock -1 hour at a time or +1 hr at a time.
Enjoy :)
