Clock did not adjust after daylight saving
gman2233
First post so please be kind....
My father-in-law CX-9 clock is an hour off. After daylight saving the time has been an hour ahead. I look thru the manual but can't find a way to change the time. Is there a way to change time zone?
Do you have navigation on your CX9?
If yes, clock can be changed under "menu" list.
You can only +/- hours.
If not, I can't help you.
If you don't have NAV there is a clock button on the radio. Hold it and then you can manually adjust it. The Non-NAV radios don't auto adjust for DST.
Clock of CX9 with NAVI does not auto-adjust for DST either.
NAVI Sat. runs on universal time (likely the Greenwich time).
However, the minutes are always accurate within 1 second. (like most atomic watches)
That is a very minor benefit of having NAVI system.
I have the same problem. I just bought my 2008 CX-9 GT, with Nav. The proper time displays on my Nav system, but the incorrect time displays on the temperature display panel. The only thing I can find about it in the User Manual says to refer to the Nav manual, which I don't have...
Please know that an electronics version (PDF) of Owners' manual is FREE.
- goto mazdausa.com
- Owners -> myMazda (register as an owner with VIN info)
- You can access to several documents for your CX9 including recalls notices, etc.
PDF version is much easier when it comes to searching.
Ceric, I think CX9 SportOwneris just messing with you...he lives in Arizona and they do not practice DST....nonetheless pretty funny....LOL!!
I knew.
My answer would make him happy either way. (sssh)
Any body who works with computers knows about DST....
Clock still isn't fixed
Okay, I've search the danged manuals. The owner manual tells me to press the clock buttons and H and M buttons... I don't have these buttons. It says to refer to the nav manual if you have nav. I do. So I go there. The nav manual only tells me how to adjust the time on the nav display. But I want to adjust the time on the information display panel, not the nav - I figured the nav one out no problem. Any suggestions to adjust the information display when you don't have a clock button?
Hmm. When I adjust the time on my NAV, it automatically adjusts the time on the information display. I've never heard of them being out of sync.
Sounds like some type of electrical connection or programming problem.
