Just wanted to thank you guys again for voting me in for MOTM last time, and start logging what's going to be a very long-term transformation I'm working on. If anyone was wondering what the "Circuit Heart" livery is all about, please let me list a couple things in my shopping list:
- A junkyard Tesla Model S
- ~20kWh battery pack
- semi-DIY electronic speed control
- custom rear subframe+suspension
Here's where we stand today; I wonder what it'll look like by the time we're done.
Power/MPG:
- Cut-airbox SRI
- JBR Skyactiv Panel Filter
- Custom Magnaflow 11132 exhaust w/ 3.5" exit
- Ford E-Focus Rear Motor Mount
- BC Racing ER Coilovers w/ custom digressive valving
- Swift Springs 9kg/mm F
- Hyperco Springs 650lbs R
- SPC Rear Camber Arms
- Corksport 28mm RSB
- Hotchkis Billet Sway Bar Brackets
- Corksport Rear Toe Links
- Tri-Point Rear Endlinks
- Powergrid Front Endlinks
- GTSPEC Front Strut Tower Bar
- Corksport Mid-Chassis Brace
- Mazdaspeed3 front brake conversion
- Mazda5 rear brake conversion
- Stoptech Street Performance pad set for Mazdaspeed3 F/R
- Stoptech stainless lines F/R
- Edelbrock speed bleeders
- Enkei NT03+M 18x10.5 +30 F/R
- Bridgestone RE-11 285/30/18 F/R
- Touge Factory hubcentric rings
- Eibach 10mm spacer F
- Adaptec 12mm spacer R
- ARP extended wheel studs
- Muteki SR48 Burning Blue Neon lugs
- Garage Vary Replica Front Lip
- BMSPEC birch plywood front splitter
- 240ZG Fender Flares (4x fronts)
- Bayson R side skirts
- SPMS P1 Spec Rear Wing
- BMSPEC custom wing endplates
- BMSPEC custom wing risers
- BMSPEC custom rear diffuser + subframe
- VG Sharkfin Antenna
- BC rear damper remote adjuster
- Custom eccentric aluminum shift knob
- Works Bell steering wheel hub
- Momo Mod.08 steering wheel
- Custom clamp mount for OEM airbag+horn
- Rustoleum Satin Black headlight housings
- Hella Optilux Extreme Yellow 65W 9005 high beams
- Hella Optilux Extreme Yellow 55W H11 low beams
- SuperBrightLEDs 7443 turn signals w/ load resistor
- Corksport LED Hatchback Brake Light
- Brake light flasher circuit
- Hella Supertones
- Rear wiper delete
