Would like some help. I not a mechanic, or a millionaire, but am teachable. I apologize about this being so lengthy but here it goes...
2002 Protege5 automatic no mods
145,000 miles
A few weeks ago CEL came on: P0303 / P0660 / P1659
Replaced plugs and boots (which were less than 2 years old and looked fine).
Plug wires are less than 2 years old and good ohm reading (checked the same new set at parts shop to compare)
Coils ohm showed good.
Checked for vaccuum leaks.
Days later the CEL came on: P0303
Cleaned MAF sensor
Cleaned throttle body.
Checked again for vacuum leaks
Swapped coils around (to see of misfire cylinder changes).
Days later the CEL came on: P0303 (I guess that probably rules out the coil since I swapped them). Did the following:
VICS valve actuator (rod) was not moving so I swapped soleniods, with VTCS soleniod. Bad soleniod, a $100 fix (ouch!)
Checked all the hoses (again) for vacuum leak(s).
Checked and spray cleaned the electrical connections (yea I'm deperate).
Removed and cleaned the EGR, replaced the EGR gasket.
Went highway driving and CEL came on at 50 miles. I was accelerating, from a slow speed, to get onto the freeway. Car felt like it was struggling and the CEL came on -flashing- and the ride was struggling (doing 45 mph by now). I pulled over, shut her down, waited a minute, then started it up. Had a solid CEL. Drove 50 miles back home. (It happened at night so no AZ open to read code).
Here are the Symptoms:
While car is idling (any gear) will be around 700-800 rpms and will drop 50-100 rpms for a split second, like a bump. It is random (maybe once in 15-30 seconds or it could happen four times in 5 seconds, no specific pattern. It is doing it more frequently than when it started a few weeks ago. I don't notice it when driving at higher speeds/rpm, if it is happening it is very subtle.
________________________________________
Issue 2 (could this be a cause of the CEL)
While addressing the VICS solenoid issue I noticed the VICS and VTCS valve actuators (the gold disc/dome looking parts with a rod extending from them)look the same. When I was manually checking them -
VICS actuator moves easily (both directions - the spring moves the rod to go back immediately.
VTCS actuator is harder to move and when you release pressure, the spring moves slowly (I can move my hand faster than it goes back)
Dealership says they don't sell the parts separately, I would have to buy the unit they are attached to (shy of $600). Parts guy is going to call mazda tech and see if:
1. Are they the same part
2. Do they sell them individually
Was wondering if anyone here knows if they are the same part and how is there a DIY way to check them..
I will be coming back with questions/suggestions on my CEL issue after my trip to get the code read (again).
145,000 miles
Cleaned MAF sensor
