Changed Spark Plugs And.......
dj JINX
MSP
i just switched to the the copper ngk plug. Did anyone notice any "performance" changes after they did so? Maybe its the fact that these are new plugs....but the car idles smoother and pulls thru the rpms smoother too????? Maybe a just me too but its like 32 degrees out side and i did a few 10psi runs with no fuel cut weird
Please post the plug number and gap you are using.
367 (mspyellow
The benefits you guys said, do they only occur on MSP (with turbo)? If so, I'm interested to get a set... but not sure where to get them..
I'd think the benefit of the copper plug is greater in a turbo car.
You'd probably be better off with a platinum tipped plug in an N/A car.
yeah jimmy,
we run much higher internal temperatures
i dont think P5 engines run that high
I did over a hr of driving tonite and the diff is unreal You should be able to get them from a motorcycle shop. Im the part mgr at one and the where very easy to get
hey jimmy,
the plugs are not that expensive, try to get them, i wonder if they would make a differense in a P5....
if it drives and pulls smoother, it's worth it.
Me too..
Got one tomorrow and one on Weds..I just CAN'T wait til this is over..I'd be SOO relief.
Good luck on your exam.. :D
