Cels after tranny swap
blazinrola80
msp 03
the kid i sold my msp too. had broken the tranny i recently swaped it in and car now boggs and is slugis .. cel poped up checked it reads..
po 507- idle air control high rpm
po 850 park neutral safty switch circuit...
did i plug 2 wires backwords on the tranny by the diff.. my guess.. car was running perfectly fine before that with the exception of a bad tranny..let me kno what you guys think or solution to the problom thanks.
PO507: unless i'm way off base your IAC must have taken a hit somewhere
PO850: ???
I did a quick search online for PO507 and I found a few entries that said the 507 and 850 are related...might want to google around a little for more info...might help
sounds like you forgot to plug in sensor some where?
was it a msp tranny or some other one from another fsde engine? because the trannys are the same, but they are missing a couple things for sensors.
no it was a msp tranny.. out of a yellow msp.. now its also blowing the fuel pump fuse.. ok im going to see what i find on google..
after broken waste gate was fixed and steed speed mani instaled.. problom still exist.. rpms change when i press the clutch.. .. any ideas..
