CEL: too rich-wtf?
'03.5 MSP(Yellow!)
Alright, now I've got a CEL for too rich on sensor 1. I was pretty sure this was the case, but I wasn't sure. I'm wondering if the 255 lph fuel pump could be causing it?? I have the stock pump at home, but I don't see how this would really make a difference.
-Mateo
yes the fuel pump would cause it because of the high pressures... and so would an exhaust leak
no A/F gauge yet. My dad's letting me borrow his AEM out of his FD for a few days; I'll see if that shows me anything. You're kidding about the exhuast leak, right? Unless it was before the O2, i don't see how in the world that would make sense. even if it WAS b4 the O2 sensor, i can't see it making that much of a difference.
Also, would higher than normal fuel pressures throw a CEL?
-Mateo
Tried replacing the fuel pump with the stock unit. Same results. I'll try the regulator next. Any other ideas?
-mateo
-mateo
did u reset the cel after u got it back in? n drive it around a bit?
im throwing the same code. Does your car feel like it lost some hp?
mine's a bit insane. I've purchased CWill's old MAF, perhaps the one I have is just dead.
I completely took the turbo system out of the loop today, made a short intake pipe, and ran the car NA. Took me 20 minutes, and it shows you how riduculous 200 dollar intakes are. However, the car still runs insanely badly, but I have ruled out the possibility of a pressure leak in the turbo system causing the issue. It could still be a leak in the manifold, but I sincerely doubt it.
-Mateo
