Cat Delete Question
RImazda6
2005 Mazda6 S
Is there any way to put a cat delete pipe on a Mazda6s 3.0L without getting a CEL? Anyone try a MIL Eliminator or angle block for the o2 sensor?
Sorry if this is a repeat post...
Should be able to remove the 2nd cat without issue. Not sure where your cats are located on the vehicle, can you share a little more info?
As long as the second o2 sensor is before the second cat you'll shouldn't have any issues. If the motor is like the V6 in the Fusion you'll still want to keep a reasonable amount of back pressure. You're not going to want to burn a valve.
