Car doing craptastic things
PimpDaddyJ
Mazda Speed 2003
Heres my little issue, just wanted some input so i can put my mind at ease.
I was at a stop on a steep hill waiting to make a right turn onto yet another steep hill. Due to the steepness the only way i could get the car to make the turn and go up the hill was at 4500+ rpm and then punch it since the car would bog down and just creep at anything lower. So i get on the other hill, and shift to second at 5500 rpm, the RPM jumps up to 7000 and then keeps bobbing around , i shift to third...no power, no go, rpm still bobbing, tires were not spinning, engine was not making any high reving noise..foot off the gas at this point, put the brakes on, waited a few seconds, shifted to first and gave it a little gas and once again power and everything was fine...any ideas? gears were fully in when i shifted...there was a slight order of clutch burn....car has 53,000 km on it and is stock (scratch)
Your Car Is Possesed!! Run!!! Someone Quick, Call The Ghostbusters!!!
that musta been one hell of a steel hill if you had to rev it that high.
Let me put it this way, if it was any more steep of a hill it would have been a wall (peep) ...doesnt help that front tires are close to being bald... It also could also be related to something i did with a member of the opposite sex in a church parking lot at 3 am (hump) ...oddly enough this problem and the bad squeaking of the new bushings in the back appeared right after this event...
or its time for a new clutch :'(
