regdent said:i not long had the mazdaspeed, it has a bov on the tb to ic. but that is sucking in air and not closing properly, so i ordered a greddy and i am not getting that until monday and i need the car done asap so i am taking in to a garage who i guess will put another greddy on there. leaving me with a spare one just wondered if to sell or use it.
regdent said:can i replace the stock bpv with a greddy type s as well as having one on my tb to ic pipe??
DSMConvert said:no reason...a single type s will vent up to 30 psi at a t4 equivalent cfm flow rate.
DSMConvert said:no reason...the only reason to ever, thats right everyone else i said ever, to use 2 bovs is if you are pushing over 30psi...period end of story turkey or no turkey...a single type s will vent up to 30 psi at a t4 equivalent cfm flow rate.
DSMConvert said:hehe kiddo if you think how long I've been on this site has anything to do with my knowledge go back to highschool....my statement referred exactly to his question, in no way did it have anything to do with the dual setup. To verify my statements I called directly to Greddy technical support and talked to an engineer named Mark. He verified that there is no reason to run dual greddy BOVs for boost applications under 30psi. Now to state once again there is no reason to run dual greddys. Please notice that this i just said DUAL GREDDYS, not in any way did I refer to the dual setups being run on this forums. I dont know who pissed in your cheerios this morning but get over it and make sure you read the post before raising a stink, obvisouly tx demon read it b/c he commented on exactly what i was talking abou. OH yeah and to add to my credentials I hold a degree in mechanical engineering and am ASE certified. In addition I also own my own company that designs air systems.
Notorious said:I will tell you this. There is no way to run a single greddy type-s on my car without either surge or leaking under idle. Thats why I did the 2 valve setup.
DSMConvert said:Hmm well I guess we both(myself included) owe eachother an apology for jumping to conclusions on the other's statements...my posts were not meant to start a war either, I was just saying that running two greddys isn't necessary. As you indicated people have had success with running both the bpv and bov together, however I haven't seen anyone yet who is running 2 bovs...perhaps we were just on different planets as to the difference between bpv and bov...when i say bov I mean a valve that vents to atmoshpere and having a valve diameter of atleast 1 inch, a bpv on the other hand is a recirc device around 3/4 of an inch in diameter. I completely agree that running a bpv with an atmosphere dump bov is a good idea when using a maf setup...
TX Speed Demon said:...If however you want to run 1 GReddy venting so you have the nice BOV sound, then running another BOV recirculating is a good idea.
TX Speed Demon said:I think the reason 505 had to run two valves is because he uses the HKS SSQQ instead of the greddy type s. The HKS pulls less air all at once, so when recirculating you don't stall, but you get mad turkey. The greddy releases more air all at once which helps prevent the turkey. 505 may also be pushing higher boost levels than me so that may have something to do with it.
505zoom said:Well, if you remember way back when we were trying to figure all this out last year, Discreetspeed and I both tried a bunch of things (he was using the type-s, I was using the SSQV). We both had similar results all along the way, and both had the most success with a venting valve + a recirculating valve. So basically I just don't *think* that the SSQV is what was causing the issues... DS and his type-s were doing the same things.
casper said:505, I don't mean to threadjack but I LOVE that dyno vid. So so sexy.![]()
