Cams for 2.3 mazda 3..anybody herd of any cams out yet?
Unground cam's are available from mazdamotorsports for the hardcore.
Remember that because of the keyless crank and timing chain...replacing the cam's in the 6i is a bit more extensive then other cars. Make sure to look over the service manual @
http://www.mazdatechinfo.com
Before purchasing cam's, so your aware of the difficulty level and tools required. (Some which must be purchased through mazda)
Mazda3 Cams etc.
Here's the link to MarcyMotorsports website. They have an extensive line of engine internals for the 3, complete heads already ported and fitted with titanium lifters, valve springs and cams, cam adjustment tools, pistons, shortblocks etc. the list goes on, This is THE site for serious NA or turbo enthusiasts for the Mazda3. Check them out:
http://www.marcymotorsport.com/html/parts/mazda_3.htm
Avery
Avery
From what I can tell, those are all Duratec parts and won't work with the Mazda.
Really what won't work that you know of? I do know thoat some of them need to be tested.
Well, the pictures of the heads they were showing didn't have VVT. That's the one that jumped out at me.
Since the heads (from what I've read) are completely different between VVT and non-VVT, I'd say it's a safe bet that the valves, springs and cams are probably different, too.
I could be wrong. Unless you try it or verify part numbers, there's no way to be accurate in a conjecture.
I'm not willing to be a guinea pig, though. (dunno)
in short words (Bear With Me(hi) ) Duratec non vvt cams in a mazda built vvt head=(nervous)
three said:
So would the cams on that site go on the mazda 3 without messin it up.
He is quite aware of the VVT that we have and I'm sure if they are listed they will work. MarcyMotorsports is very capable of producing some very nice parts.
