Gents,
I did do a seatch first and didn't come up with much. Hopefully yous guys can help me out.
I have a 08 MZSPD3 and have recently put new tires and had both of my wheel bearings replaced. I had some major shake from the drivers side front wheel. My mechanic found a bad bearing and I just went ahead and replaced both.
Since then, I get this ABS (I think) pulsation. It isn't all the time and doesn't happen under any type of circumstance. I have taken to my mechanic twice and they can't find anything worng with it. And of course it doesn't happen when they drive it!(uhm)
This didn't do this prior to the wheel bearing being replaced. It happens under light breaking and a little harder breaking. It feels just like the ABS system kicking in for a brief moment. My wife says it sounds like grinding to her. But I can feel the pedal back off like it does in snow.
Anyway, I was hoping that someone else has had the same issue and had it fixed. I will try one more time with my mechanic to see if the problem occurs. I feel that they are responsible since it didn't do it before getting the bearings replaced!
HELP!!!!
Dave
HELP!!!!
Dave
