Brake Light Stays On @7k
Mazdaspeed3, GT
Hello fellow Mazda peeps!
I have an '08 MS3 with 7000 miles on it. Its not much of a problem but my brake light stays on for some odd reason. It's intermittent. The brakes don't make any grinding noise, etc... I was just wondering what to check. Sorry...noob here. If its just the brake fluid that needs to be topped off, what kinda brake fluid do I buy?
Thanks!
Ivan
Thanks!
Ivan
There is a mark on the side of your brake fluid reservoir indicating acceptable level. DOT grade of brake fluid is indicated in your owners manual along with warning light descriptions.
-enganear
Thanks...
Refilled with Prestone Synthetic DOT 3. It was really low. I checked for leaks, etc. I don't think it was checked when I took it off the lot..... weak.
