Brake Booster Bov Line - Everyone Might Want To Know This
mazdaspeed75
ZOOM ZOOM BOOM BOOM CLUB
2003.5 mazdaspeed
After a long run around . Found a y connerctor at autozone to tap into brake booster line for my hks ssqv bov. Let me tell you this makes a world of difference no turkey at all . Seems to respond 100% better. Still need to tune some its raining hard here. Thought everyone would like to know this. May be a repost. This and all the vacum line sources should be sticky. Thanks 505 zoom and linux racer for answering my questions I appreciate it. Thanks Tony
Right on man, good to hear.
I have been thinking about your spiking issues, and you should contact me on AIM. I have a couple of ideas for you.
hey whats up, ive been looking at the HKS ssqv bov a lot latley, id like to get some feedback about how it runs, possible some vids or more pics? thx
i
great if you do the dual setup i havent figured out how to get my digital camera to my computer yet it want go with usb cables
Here are some vids that show the difference between my SSQV setups:
<B>Recirculated SSQV ONLY:</B>
http://www.wpi.edu/~jck15243/MOV00495.MPG
<B>Open-vent SSQV with stock BPV:</B>
http://www.mazdamp3.com/members/505zoom/mov00533.mpg
<B>Recirculated SSQV with stock BPV:</B>
Low boost throttle lifts:
http://www.msprotege.com/members/505zoom/MOV00595.MPG
Mid boost shifts at about 4K:
http://www.msprotege.com/members/505zoom/MOV00594.MPG
Full boost shift (11psi), at about 6K in second:
http://www.msprotege.com/members/505zoom/MOV00593.MPG
Flying Miata makes a Brake booster line "vacuum" source. $24.95. Just got it and it has 3 taps. It's part of their Protege kit - signal source fitting 02-5P070
h I
Make sure when you tap into it to do it in the middle because on the left side towards the brake booster there is a check valve in there feel around for it . I said feel . lol (outie)
which line is it exactly? Can a better pic be taken in the light?
Thanks.
-B
Thanks.
-B
I have this pic for now, I'll go take another one for you and get a better view of which line it is.
This one is a little better. It's the fattest looking hose because it has a large sleeve around it. The arrow points at the easiest spot to find it.
[/QUOTE]
Wow...great pics...that answers alot of questions. Did you use that as your Boost gauge source also? It looks like your 2 gauge lines run to different vacuum sources from the pics.
err, yea, i have my boost gauge and FCD tapped there. I'll probably try switching my BOV to that, and my gauge off my BOV tee or something.
