Bought Sway Bars, Do I need the AWR Endlinks Too?
silverspeed03
Boost Junky
2008 MS3
Hey I bought the Hotchkis Sway Bars and wanted to know if You guys would buy the end links also? I thought I read on here that somebody had a problem with the stock end links breaking. I'm just wondering if this is something that I'm going to regret not purchasing down the road.
i say get them especially for the front once you put it on you don't want to have to go back and replace the endlinks. i am not sure if there are beefier links for the rear yet but i would go ahead with the fronts they aren't that expensive and they give you peace of mind...
Well Once you get the front bar in the hard part is done. Replacing the endlinks is fairly simple after that. But they will probly break so you might as well get stronger ones while you are at it.
