18psiWhiteMS3
Banned
- 2009 MazdaSpeed3
When i first installed my cobb map it was in the 50's and 60's outside and it would boost peak 20 and settle to 17 at 6250 rpm in 3rd and 4th.
Now that it was been warmer out, in the 80's I am noticeing my Boost peaks are exactly the same but my Boost hold has dropped down in the 15's near 6250 rpm.
I just changed my oil to a full synthetic and when i did that i tightened all my clamps and they are deff not leaking. What i wanna know is that normal Boost numbers for that map?? The cob says 19psi + or - 1.5 at 6700 rpm so that means i should be sseing 17.5 at the least am i correct?? so why am i seeing 15 now?? is it normal to have a lower hold in the warmer temp?? Just trying to figure this s*** out cause my dyno is soon approaching and i want the car to be boosting what it is supposed to.
BTW my Fuel pressure is still in the 1700's at redline
