boost pressure question
jaymz199
09 mazdaspeed3
Ok well im new to mazdas and new to boosted cars. i just picked up my 9 mazdaspeed 3 about 3 weeks ago. it had 2 busted motor mounts from the get go and i just replaced them today with minerva mounts. wich imo are not that bad and they dont vibrate very bad at all. well when i got the car it had a fmic injen cold air and hks bov manual boost controller and a boost gauge. ive noticed that in fourth gear if i do a pull the boost will hit around 15psi and when i get close to 5k the pressure starts to bleed of and hits 12psi at about 5.5k i was just wondering this is normal or if its just pulling boost because maybee tha fuel pump is maxed out and it cant hang? I do not have N acces port yet but im saving for one now so i cant monitor anything atm... any advice would help and if i misspelled anything im sory im posting from my pos phone
All i really whant to know is loosing 3psi by the end of the gear normal or is ther a problem i should be looking for
Those pressures seem a little low to me. Could be from the extra plumbing for the fmic.
In any case you should be spiking to generally 17psi and tapering down to about 14-15 on stock tune and equipment
with a different tune you can hold boost higher for longer, as well as a general increase in psi across the full rpm range
Well it spikes around 16 drops to 15 and maintains 15 until about 4800 then it starts to drop from 15 and at 5.5k its at about 12psi
So the pressure bleeding off is normal and maybee i should turn the boost controller up a bit? :D
Ummmm....i really wouldnt do that with this car. There are some good tuners out there that will increase your boost along with changing other parameters so you can increase boost safely.
I have the hypertech tuner which i think increases pressure to around 18 for a spike, then tapers down to 16 or so. But along with that increase i keep power for longer (higher rpms) instead of the stock tune dropping off a few thousand rpms before redline
Thats why i ask when i got the car it had the manual boost controller and i tryed to get it boostin at 15psi so it was close to stock
Because i was getting spikes close to 18 but i didnt know what was safe so i backed the boost down
So spiking 17 then it droping down it about 14or 15 and holding and the broping again at around 5-5.5 is wher i should be right? And im guesing the ecu is what causes the boost to drop off at around 5k? thats why with a tuner it can hold boost longer?
I cant be certain about any of that. But i think the wastegate actuator as well as the boost solenoid are ecu controlled. So the stock parameters are still functioning even when manually upping your boost
but thats he reason why i say forget the manual controller and get a tuner. With the way these cars (and many others) are now you cant just mess with one aspect and get good, or even lasting results
I upped it a tad but i got fuel cut so i backed it down...you would just yank tha boost control and let the ecu do the work huh?
I didnt install the controller so nows the fun part...to figure out wich vac line goes were lol
I agree. Pull the MBC for the time being to see where you are on the stock tune. You should see 16-17 psi, maybe even 18 on the boost gauge when coming up on boost, with a gradual taper to 15 at about 5,500 rpm. After that, the ECU forces the throttle plate to rapidly close to protect the small turbo which becomes inefficient at higher rpm. I'd avoid the MBC altogether and wait for your money to accumulate so you can get the Cobb Access Port or some other tuning solution. If you are not familiar with turbos and are worried about making a mistake with maps and tuning in AP, consider the plug and play Hypertech. It produces a nice bump up in performance and does it safely. AP can produce a little more power, but if you don't know what you are doing, you can get into trouble.
BTW, load cut does come on at 17.5 psi on stock tune under most conditions and MBC does not let you work around that. AP or Hypertech give you higher load limits without cut.
Im planning on getting the acces port . but how safe is the ots maps? And its really all about driving the car and monitoring it to see what maps work correct? and im really sold on the ap because of the scantool features and data loging
