jarheadTEX
Okay I am stumped. I installed my boost gauge per the how to on the forum. I used fuse 10&12 on the inside and 21 in the engine compartment. When I went to start up, the boost gauge was working electrically but the car would not start. I took out the add-a fuse and the car starts. So I thought for some wierd reason the car knew I had replaced the 10 amp fuses with the 7.5s. So I swapped back to 10 amp and the gauge worked and the car started. I shut it down and started it again and the boost gauge doesnt work.
Any Ideas??????
Oh the check engine light came on also.
Any Ideas??????
