I have been reading and experimenting with my MS6 for 4 months now and have not even scratched the surface of mods that could be done.
I did the one muffler delete and the Cobb SRI with the Forge BOV. Now I get so much boost cut I don't know what would make me take this any farther. The car is slower 0-60 each time I get the cut then when it was totally stock! Granted if I can avoid the boost cut the car feels quite a bit faster/stronger. The problem is the power is not repeatable and when you need it it's not there.
It seems that even if I go all the way and do a ECU and full exhaust I will still see this problem. I want reliable power when I need it. If you are in a autocross or on a road course and you need the power because you are on the edge you cannot afford to be bogging down with boost cut. What can I do and in what sequence without wasting my money?
I have been tweaking the suspension because that is what I like to do to make the whole car faster everywhere. I want the power also but what the hell has to be done to get "good" power and usable non peaky power?
Thanks for listening and I look forward to your responses.
