Booost spike
06 LS MS6
07 BM GT (shell has been struck from the roll)
Hey
These are log graphs from the torque app, which I have used in the past, and recently, since the dashhawk is unsupported, all the time
As you can see, its reporting boost peak of 33, tapering to like 28.
The shape looks correct, any thoughts?
I also have a kinda detonation like grungly burble sound which is new, as it enters boost. Mainly part throttle, around town
Thanks
Mike
Refresh my memory on your mods and present setup please. Sorry I missed this post and am getting to your issue so late.
Wow, super active forum these days.............(cricket)
CAI< TIP< LAIC<DP<autotech's<HT tune
The issue, should any archaeologist care, was the torque app defaulting to a +14.7 mode after self updating
The noise? dunnostill there but not as pronounced
Clearly something wrong with your Torque app software or your dongle sending data from your OBD 2 port. Can its firmware be reflashed? Can't make boost like that on HT and stock turbo, for sure.
Have you tried to hard boot your phone? Pull battery and reboot from scratch? Have you tried to delete and reinstall the app? For piece of mind, I always run a true mechanical boost gauge fed from a vacuum line off of the bypass valve. They are cheap.
