Blue wire in engine bay to sensor?
Hi,
changing the oil in my car, aware of a bit of a leak from the pressure switch - but it might actually be from whatever is above it - but not sure what that is.
Picture shows view from ground underneath the car facing to the sky.
The pressure switch has the light coloured wire going to it, but the blue wire is as yet unidentified?
Can anyone help?
Thanks
I think (hard to tell exactly from angle) that is your knock sensor. If you do unscrew it, there's not an oil or coolant passage, it just screws into block. I replaced mine because the back of it, which is made of some type of silicone, melted or just disintegrated down the block like what yours seems to be doing.
Edit: looking at it closer, I'm certain, that it is the knock sensor. It looked like the blue wire was part of the nut/stud on the intake manifold due to the angle. But zooming in, it looks like your knock sensor.
